Rims/Tires for 2005 V70
Old Oct 30, 2018 | 09:22 PM
DPK_84's Avatar
Default Rims/Tires for 2005 V70
I'm trying to get my hands on some used winter tires and rims for our 2005 v70. I am considering driving an hour out of town to pick rims sized as follows with winter tires already mounted:
Bolt Pattern 5x108 mm Hub Bore 65.1 Nut or Bolt bolt Nut Bolt Thread Type M14x1.5 Nut Bolt Hex 19 Bolt Length 27 Minimum bolt length 26 Nut or Bolt Torque 103*
Will they fit? Not a wheel/tire specialist and hoping someone can help me.
Thanks,
Dan
Old Nov 1, 2018 | 05:44 PM
yes your car has 5x108 with a 65.1 MM center bore and uses 14x1.5 bolts.
For winter tires you should be looking at 16 inch rims with an appropriate offset to the rim width (ie 7Jx16 ET43) and something like a 215/55-16 tire.
check out wheel-size.com for all the info.
Old Nov 4, 2018 | 10:41 AM
pierremcalpine's Avatar
Offset is important - as long as it’s within 5mm of original you should be fine. Offset will dictate whether the rims will sit further out from the wheel well or further in.
DPK_84
Nov 1, 2018 05:36 PM
Nova Scotian
Dec 19, 2014 01:01 PM
jbooker82
Oct 19, 2011 05:25 AM
dsbloom
May 28, 2009 10:08 PM
newvolvoguy
Nov 18, 2008 07:04 PM
