Timing belt change oscillation damper
I posted this on the V50 forum but it applies to V70 as well and there are more V70s out there than V50s.
I recently change my timing belt. In the process I removed the oscillation damper ( harmonic balancer) using my impact wrench. On the refit I used the impact wrench to tighten the crank shaft nut. The first attempt there was was a fairly significant whuup whuup whuup noise after a 10k test run. I retightened the crankshaft nut and the noise is much fainter but still there.
My question is about the balancer. I saw somewhere that you should not use an impact wrench, you must be careful when pulling the damper off, the damper has a life expectancy less than that of a timing belt.
So, did I corrupt or compromise the damper during removal and refit ?
What is the best process to follow ?
Is an aftermarket balancer a good idea or do I have to get an OEM one ?
The car runs great - fun to drive T5 M66, has a lot of K on it, not worth spending a lot of money on it.
91Volvo240survivor
Feb 7, 2022 08:18 AM
91Volvo240survivor
Nov 14, 2021 04:45 PM
