torque specs
Old Nov 1, 2014 | 11:46 AM
slashmaxx242's Avatar
Default torque specs
I have a t5 v70. I am in need the torque specs/order for the valve/cam cover.
Old Nov 28, 2014 | 08:38 PM
mustang8573's Avatar
Here's what I found. Also see attached pictures. There are very specific instructions for installing the cover and how to apply the sealer.
-Lubricate the camshaft lobes, the camshaft bearing surfaces and the tappets.
-Install the camshaft cover.
-Install 2 press tools 999 5454
-Pull the camshaft cover alternately down, keeping it parallel to the cylinder head with the press tools
-Install all the screws and tighten.
-Remove the press tools.
-Install the spark plugs. Tighten to 30 Nm .
-Install the control valve for the variable valve timing unit with a new gasket. Tighten.
I can't find specific instructions to a torque setting for the cam cover bolts, just the one for the spark plugs.
lowbeer
Jun 5, 2008 08:59 PM
mirubbish
May 10, 2007 12:38 PM
jmalkames
Mar 10, 2007 06:02 AM
XL883L
Jun 27, 2006 06:30 PM
ewl940
Apr 24, 2005 03:52 PM
