V70 2004 won't start
well the shifter's PNP position sensor does integrate with the starter circuit but that's only one possible issue. Any sounds when you turn the key? (ie the starter solenoid clicks but doesn't engage ) cabling to the starter is another possibility, or it could be the starter itself. Did you check all fuses? (owners manual will show which fuses control the various circuits). I assume you are not getting any immobilizer warnings (but as a simple check, lock/unlock the doors 5x with the fob is one way to reset the immobilizer).
