Vacuum Assist Pump After Booster Replacement
I just changed my brake booster because I was getting the hissing sound coming from underneath the dash. I was able to pick up the booster from a recycler for $100.
The hissing has seemed to stop. However, I am still having an issue with the vacuum pump assist. The pump will cycle for about a minute after the car is turned off. This problem started when the hissing sound started. I was hoping that by replacing the booster both problems would have been solved.
Any idea what is causing the pump to cycle after car is turned off?
Let me add, this is an '03 V70 with 170k on odometer. Base 2.4.
No CEL lights on dash.
Any input is greatly appreciated.
Thanks
Thanks
