What other year and model radiator cooling fans will fit my 2003 V70XC?
New to me 2003 V70 XC. My current radiator cooling fan is running continuously after the car is shut off, until the battery dies. Need to replace the fan (I have read on another forum).
Wondering what other year and model Volvo radiator cooling fans will fit. Local wrecking yard has 3 1998 V70 wagons, most likely has other sedans and wagons, but I only searched for V70. Brian in Austin |
Surely the fans function is related to the engine temperature sensor? ECT
If the fan in fact runs then the unit itself must be okay. Alternatively you may have a faulty thermostat or the radiator core might be clogged. |
Originally Posted by difflock54
(Post 367920)
Most of the posts I have read on all the Volvo forums relating to radiator fans, running on seem to have been resolved by replacing the ECT, or the thermostat.
Seen some referring to maf also?? strangely. How can the fan still operate if the integrated switch has in fact 'shorted' out. Wouldn't that blow a fuse and stop it? (sorry, I dont profess to be an auto electrician) Also was wondering if your V70XC is actually running extra hot or overheating currently? |
He's right, its common for the fan control module to stay on.
Thanks ES6T for clarifying that.
So could he simply replace the control module or is he up for another whole fan assembly? |
Have you seen this bcolins
This link to IPD shows models compatible and lists the years compatible. Electric Radiator Cooling Fan & Module S60 S80 V70 XC70 |
(Post 367938)
This link to IPD shows models compatible and lists the years compatible. Electric Radiator Cooling Fan & Module S60 S80 V70 XC70 Read about it on the XC forum. Brian |
(Post 367936)
So could he simply replace the control module or is he up for another whole fan assembly? Brian |
Dont blame you with that price difference.
Has a warranty too so better option than a 2nd hand part ex wreckers. |
Update
Replaced the cooling fan assembly with a new unit from Rock Auto yesterday. About a 30 minute job.
It did fix the problem. Brian |
