Yet another cruise control thread... help!
Old Nov 26, 2023 | 01:19 PM
vandelayindustries's Avatar
Default Yet another cruise control thread... help!
Hi. I hope you guys can help me
Last week I bought a 2006 V70.
Cruise control worked to begin with, but now it doesn't.
The cruise control buttons don't illuminate and "never" did (volume buttons etc. do)
No error messages in the instrument panel.
I've done the clutch position sensor test (clutch down, neutral).
Brake lights work when I depress the brake pedal.
I've had the airbag off and checked the connectors.
The brake booster vacuum sensor makes a long buzzing noise on startup and every 5 seconds with ignition in position II and when I depress the brake pedal ... (?) I've taken this off, and it hasn't changed anything ...
I don't have a fault code reader, is there anything else I can check before taking it to a mechanic?
Thank you so much
hgshaw
Oct 13, 2021 02:53 AM
akb427
May 6, 2021 06:28 PM
russ
Mar 8, 2017 10:10 PM
derrickb
Jun 9, 2013 10:20 AM
Oly Volvo
Oct 26, 2009 10:37 PM
