2007 xc70 transmission hard shift / clunking
Old Feb 13, 2018 | 05:29 PM
Mc_Gusto's Avatar
Default 2007 xc70 transmission hard shift / clunking
my wife is experiencing a ‘hard shift’ of sudden change of gears primarily between 1st and 2nd causing the car to really clunk and lurch quite dramatically. It was happening infrequently but now seems increasingly common
any ideas? Is it a common problem? Hoping it may just be a fluid issue and not a transmission replacement!!
thanks
Old Feb 17, 2018 | 07:31 AM
tony1963's Avatar
It is a very common problem. I've helped dozens of people in this forum solve the issue inexpensively.
PM me for more information.
BTW - you can run an oil tanker's worth of fluid through that thing and it WILL NOT CHANGE THE SHIFTING PROBLEM.
Old Feb 20, 2018 | 11:25 PM
Mc_Gusto's Avatar
thanks for your offer to help, I’ve sent you a PM
Old Feb 21, 2018 | 08:18 PM
Mc_Gusto's Avatar
If anyone else can help please do. I’ve booked it with my mechanic for next Friday!
Old Mar 18, 2018 | 08:22 AM
dgoldsmith's Avatar
Curious if you had your 'clunk' fixed? I have a 2002 with 90,000 miles and have had the clunk for a few years and decided to live with it - assuming that the cost of the fix doesn't make sense for a +/- 16 y.o car.
thanks
Old Mar 18, 2018 | 12:09 PM
tony1963's Avatar
The fix is not that big of a deal. The hard shifting will eventually damage the transmission. For about $200 you can DIY.
Old Mar 18, 2018 | 02:43 PM
Mc_Gusto's Avatar
I traded it - the transmission was stuffed
Old Mar 18, 2018 | 04:18 PM
Mc_Gusto's Avatar
By the way we experienced the clunk for a few years
the most recent symptoms were similar to that of revving the car in neutral and then dropping it into first...literally spinning the wheels on some ocassions
i would have put up with the clunk but the wife tows the kids around and I felt it was a matter of safety
traded it for a 2013 xc90 R design TD 5
very happy
Old Mar 19, 2018 | 06:58 AM
dgoldsmith's Avatar
Thanks Mc_Gusto. Ours isn't as bad as yours was (yet) and so far my wife seems ok to put up with it
Old Mar 19, 2018 | 06:59 AM
dgoldsmith's Avatar
Tony 1963 Soo..... what's the DIY fix?
Old Mar 26, 2018 | 08:45 AM
tony1963's Avatar
PM me and we can discuss. I no longer provide this support on the board since several armchair mechanics tear me apart when I attempt to help.
Old Jul 18, 2020 | 01:25 AM
Roy White's Avatar
the fix is not that big of a deal. The hard shifting will eventually damage the transmission. For about $200 you can diy.
i am open to sugestions sir
Old Jul 22, 2020 | 10:06 PM
i m r an's Avatar
thanks
hi Tony ,i got the same problem with a 2006 xc70 and it actually comes back into first gear from fourth or fifth at around speed of 50 mph . And kicks in really hard almost stops the car. Can you please give me the solution also. Thsnk you. i have stopped driving the car its iust sitting since its so scary , noisy and dangerous. i just joined this forum . Thanks for your time. you can also email me at alfredkhan6887@gmail.com
Old Nov 3, 2020 | 05:14 AM
Shifty's Avatar
Hi Tony1963,
I've just joined this forum and noticed that you have a fix for the harsh shift 1st - 2nd. Can I please ask is it fixable via cleaning out the solenoids?
Thanks in advance for your help!
Cheers Shifty
Old May 31, 2021 | 11:43 AM
fivhole's Avatar
More info on the trans clunking fix?
Old Jun 2, 2021 | 02:16 PM
JenniferL's Avatar
Default Would like diy info
hey was just wondering if you could send me the diy info
Old Jun 2, 2021 | 11:45 PM
  #17
Shifty's Avatar
Hi Jennifer, I was reasonably lucky in that my vehicle had only travelled 110,000kms so the transmission was in good condition. The problem is with the 3 Linear solenoids (black, green and blue) If the fluid is not changed regularly they gum up and stick when the transmission gets hot.
if you look on YouTube there are several videos of people with the same issues and how to fix it. Do Not try and repair the solenoids, replace with new ones. If your vehicle has travelled over 250,000kms this may not be the only problem with the transmission as bushes will also have wear and tear.
If you replace the linear solenoids and transmission fluid it should go a long way to resolving the harsh shifting issues.
Good luck, Cheers Shifty
Old Jun 18, 2021 | 06:51 PM
  #18
BobBerger's Avatar
Shifty,
My clunk is happening when we pull up to a stop sign. do you think this would be the same fix? I have a 2006 XC90 and we just turned 100,000 miles.
Thanks
Bob
Old Apr 30, 2023 | 08:25 PM
  #19
plaganiere's Avatar
Default How to fix this
Hi Tony,
I saw this post on the forum.
I have these exaft sympthoms. If you have any hint on how to solve this issue, that would be very helpful.
Thank you for your help!
Thank you
Patrick
Old Jul 17, 2023 | 04:04 PM
  #20
Ria's Avatar
Ria
Default Hard Shift please help me 2005 xc70
thanks
please let me know what you can do to stop the hard shifting
