ABS/DSTC warning light
See if you can find a friendly indy shop or a dealer that will scan/clear codes for free (I've had this done a few times). You can also see if Autozone rents (typically free in CT/NY) a full featured scanner. You likely have a true fault so I'd expect the code to reset after being cleared. Typical ABS fault codes will tell you things about the wheel speed sensors, transmission speed sensors, ABS pump, steering angle sensor, ability to communicate to other modules, whether the etc. Once you have a code, you can google for info. Also check out sites like Midwest ABS and Xemodex who rebuild the ABS controllers as they have good info on how to interpret fault codes.
Anything else going on - ie jumpy speedo etc?
Wheel sensor is green in the second picture, as is the sway bar link. One bolt holds the sensor in, you remove the sensor and move it out of the way to do spring/strut work on the earlier cars - not sure if it's required on the 08+ cars.
