-   2001-2013 model year XC70 (https://volvoforums.com/forum/2001-2013-model-year-xc70-53/)
-   -   Brake lights won’t work (https://volvoforums.com/forum/2001-2013-model-year-xc70-53/brake-lights-won%92t-work-114042/)
Mikah Brandes Aug 25, 2023 08:02 AM
I have a 2006 XC70 that has all brake lights out but I have replaced bulbs, fuses, a new REM, a new tailgate wiring harness, new brake pad sensor, new brake light switch, and the vacuum brake pump.
I’m at a total loss of ideas at this point as to what could possibly be causing them to not light up so hoping for some ideas here!
hoonk Aug 25, 2023 12:28 PM
Do you have 12v at the brake light sw? (with your $5 test light) Does the 3rd brake light work? The CEM might send the "turn on the brake lights" signal on the canbus to the REM - Water intrusion is ~common with the CEM - have you checked the CEM for water intrusion/damage?
Or does the brake light signal go on a physical green/yellow wire from terminal a:15 on the CEM to terminal a:18 on the REM - then exits to the left and right bulbs at terminal b:3 on the REM?
https://cimg0.ibsrv.net/gimg/volvofo...fb0d3ee20b.jpg
