Brake lights won’t work
Old Aug 25, 2023 | 08:02 AM
Mikah Brandes's Avatar
Default Brake lights won’t work
I have a 2006 XC70 that has all brake lights out but I have replaced bulbs, fuses, a new REM, a new tailgate wiring harness, new brake pad sensor, new brake light switch, and the vacuum brake pump.
I’m at a total loss of ideas at this point as to what could possibly be causing them to not light up so hoping for some ideas here!
Old Aug 25, 2023 | 12:28 PM
Do you have 12v at the brake light sw? (with your $5 test light) Does the 3rd brake light work? The CEM might send the "turn on the brake lights" signal on the canbus to the REM - Water intrusion is ~common with the CEM - have you checked the CEM for water intrusion/damage?
Or does the brake light signal go on a physical green/yellow wire from terminal a:15 on the CEM to terminal a:18 on the REM - then exits to the left and right bulbs at terminal b:3 on the REM?
shwebo
May 19, 2022 06:37 PM
Nate Harris
Dec 29, 2021 02:06 PM
2404me
Aug 29, 2016 10:55 AM
WalterXI
Sep 17, 2009 12:51 PM
SDozier
Oct 4, 2006 11:29 PM
