Clearing Dashboard Error Messages
I recently purchased a used 2006 Volvo XC70 2.5T that had been sitting for at least 2 years and just needed some TLC.
It is missing the ABS Module, so of course the ABS light is on. After replacing a faulty battery, numerous Bulbs throughout, some basic maintenance and getting it running well and smoothly, with all electrical power options working, it is currently stuck on 105,217 miles and showing the following error messages, that, I believe are related to the missing ABS Module and that it was not running for 2 years or longer;
9999 Miles to Empty
Power System Service Urgent
Engine System Service Required
Brake Failure Stop Safely
Alarm System Service Required
Bulb Failure Position Light
I already ran my own OBD II scanner and was not able to clear or erase any of the error messages.
I believe I have no choice but to go to a Volvo Dealer and pay for the Diagnostic VIDA DICE Service which, will hopefully clear all error messages.
Any other suggestions?
9999 Miles to Empty
2. What engine codes are present?
3. ABS module is missing
4. Probably has a bad backup battery in the siren module and needs a new siren module to fix. (or some rig with a replacement backup battery)
5. There are 4 rear parking lights, 2 on each side. 1 or more is not working or they are different brands of bulbs
Thanks for the reply.
I hope your answers are correct. Not all that concerned about the rear parking lights as they are all working, nor the alarm siren battery since the siren is working as well.
The alternator might be the power system service issue.
The ABS ilight is obvious because there is no ABS Module, but again the car is running fine and the brakes are working fine.
King Regards
King Regards
Hoonk,
The Bulb Failure Light Position turned out to be the right rear bottom tail light assembly that has water/moisture and it burned out the side marker(4)Diodes part.
The remaining error messages will need to be addressed with a VIDA DICE Diagnostic Tool.
Thnx
Thnx
9999 Miles to Empty
9999 Miles to Empty
Ccalberti,
I’m not familiar with the rear axle computer control board. Please provide a picture and the Volvo Part#.
Thanks,
EAguila
Thanks,
EAguila
rs_nuke
Mar 27, 2025 08:14 AM
