Codes on my 2005 XC 70
My 2005 XC 70 started running poorly - intermittent rough idle, lack of power. It starts ok, runs, but not good. Ran the codes at the auto parts store, they are:
- Engine Control Module (929D) - Ignition Coil Cylinder 5 Signal (354B) - Throttle Valve (9270) - Mass or Volume Air Flow A circuit range/performance (P0101) - System too rich off idle bank (P2178) With so many messages, anyone have any thoughts on the most likely culprit/where to start. So far, have cleaned the MAF, seemed to make some improvement. Pat Geraghty |
you may also want to clean the throttle body and read up on ETM issues and symptoms.
