Delay to go into gear
Hello. Occasionally my 2002 Volvo XC 70 pauses to go into gear when I shift into drive. I checked the Trans oil when the engine was warm and running and it appears to be in the correct level.
Any ideas would be greatly appreciated. Stephen |
That year had tranny issues. Check the condition of the fluid. Might be a good idea to have it serviced.
As said before, check the condition of the fluid. If it is dark and smells burnt then it would be a good idea to flush it. If that does not fix it then the only other sources would be the valve body (which is a costly repair) or replacing the transmission ( comes with a valve body)
2 Attachment(s)
Thanks all for the help so far. The fluid seems to look, smell and taste ok LOL!
The smell is a bit of a strong oil smell. Attached are a couple photos as me being an Artist a picture is worth a 1000 words! Is doing a Transmission flush something I could do and if so any links/video on this procedure would be great! I searched our forum for similar issues, but there are so many transmission issues to sort through! Just enjoying a stay home Blizzard day here in PEi! |
I think I will proceed with a flush of the transmission as shown here:
Would anyone know the best place to get the Mobile oil, filter and clips that he mentions in the video? |
Mine does the same pause before going into gear. Does your car shift well otherwise? I'm in Charlottetown, what a winter!! And it's not over!
hi joepataydis. I live in Stratford next to Charlottetown! Another storm on Wed!!
I have just finished my drain and fill for the 3rd time and the car has no more pause when shifting into drive and the overall shifting is much better. In a few weeks I will be doing a full Transmission flush with the Valvoline Synthetic oil and will post my results! No go tune up the snow blower!! Stephen |
Stephen,
Great to know you've seen positive results. I too should do drain and fill a few times. Keep me posted! Mike
Originally Posted by Stephen0523
(Post 384263)
2 Attachment(s)
Hello joepataydis and all. I am very pleased to say my XC70 has never shifted so smooth! I started by doing a drain and fill 3 times with 300-400kms between each drain and fill. Last week I did the full Gibbons / transmission flush with Valvoline Max Life Synthetic Trans oil purchased at the local Walmart. I did contact Valvoline and they confirmed the oil is for the Volvo XC70's.
I also installed the Magfine inline filter as attached here to give me the extra protection :-) I will post later on to keep you all informed! Stephen Thompson |
It's always a good idea to have the software reset after replacing the transmission fluid. the transmission software has a setting for 'new fluid' which helps it adapt to the new fluid properties.
oragex, I recently did this trans fluid flush using 13 quarts of Mobile 3309 ATF and 8 oz of SeaFoam trans tune. The trans shifting seems to have improved significantly. Still not as good as it should be. I plan on flushing it again after 2k miles to see if there is any more improvement.
I did not know about the software reset. Is this a dealer only job? |
I think it can be done with vida/dice.
Thanks for the tip Oragex. Can I reset the software myself, or is that a dealer issue?
H Oragex, what is Vida/Dice? I read somewhere that simply disconnecting the battery for 30 seconds can reset thing. Could it be that easy?
Vida/dice is a device used to read&change settings in car,s software. There are surely independent garages using it, sometimes also individuals offer cheap service on local advertising sites, worth a look:) the battery reset only works for some engine sensors
Thanks Oragex. I am willing to get a Vida Dice, but after searching I am overwhelmed what to get, will it reset the Transmission software etc. I am on a Mac but I have windows Vista Business installed via Parallels.
Any tips would be most appreciated. Stephen |
I don't have the vida myself, most people use it on windows xp/7 I think.
