How to unplug battery 2011 xc70
Old Nov 4, 2018 | 05:50 PM
Vector's Avatar
Default How to unplug battery 2011 xc70
Can someone tell me how to unplug battery and where is it located?
Old Nov 5, 2018 | 08:34 PM
not sure about your model year - if its not under a cover in front right near the firewall, then check in the trunk next to the spare. A good way to tell is if you have a jump start connector on the fuse box near the fire wall (a small door with a + sign on it), then look in the trunk under the carpeting and plastic cover.
Old Nov 21, 2018 | 09:42 AM
Vector's Avatar
Hoping someone can help me.
My car will be parked for 7 weeks. ( XC 70, 2011 wagon) Dont want battery to die.
Does idling car for 15 minutes recharged battery? any suggestion what to do ?
thanks
Old Nov 21, 2018 | 10:08 AM
a few choices 1) disconnect the battery (dunno if your model has a radio code, but if so, have it handy) 2) buy a trickle charger designed to top off a battery during long term storage 3) let it be, but then charge it using a battery charger before trying to start up again. Generally if your battery is in good shape, 15 minutes will top off a battery, but if you let it go completely flat, you may need longer and may actually disrupt the chemistry within the battery shortening its life..
Christian J. Carlander
Jul 19, 2016 09:48 AM
timer00
Dec 23, 2010 09:03 PM
NCdad
Dec 9, 2010 08:23 PM
dcjcdc
Aug 7, 2008 01:27 PM
banks358
Apr 9, 2008 09:21 PM
