B20 timing issues
Hello, Im brand new to this site but not to Volvos. I rebuilt an early 70's late 60's B20 and just put electronic points in. Ive got a weber carb, ported and polished heads, aluminum intake, cast aluminum valve cover etc. I need to set my timing and I'm having trouble. I've heard it should be around 12 degrees btdc, but what rpm should I set it at? And when I set it the rpm changes as you dial the distributor, should I try and hold a certain rpm?
Thanks and I will post some pics very soon...
I went and checked the relay ready to wire a direct +12V line to bypass the relay and found my piggy back spade terminal was grounding out my MS, injectors & pertronix +12V on the metal body of the relay intermittently. I rotated the terminal 180 degrees and had about 2 stumbles on the way to work today instead of bucking a backfiring every couple seconds. Going to datalog this afternoon on the way home to see if its fixed. Silly issues causing problems once again.
Mauritius Holidays
timeshare
Mauritius Holidays
timeshare
swederacer
Apr 26, 2012 04:35 AM
davelarue
Oct 6, 2007 04:14 PM
