Different ECU on 1,8 and B20f engine?
Old May 12, 2008 | 09:03 AM
limtopp's Avatar
Default Different ECU on 1,8 and B20f engine?
Hey I have just changed engine from a 1,8 to 2,0. I think the 1,8 enginewas B18U, but I`m not sure[:-]
Anyway.. My problem is that after I changed, the engine only goes up to 4500 rpm. When the car stands still, the engine sounds very poor.. And the pollution is very high. Is the ECU different on this two engines?
Thanks for answer
Old May 12, 2008 | 04:39 PM
billofdurham's Avatar
Default RE: Different ECU on 1,8 and B20f engine?
I assume you have a 440 or 460 with those engine designations.
The control units are different.
Old May 13, 2008 | 06:48 AM
limtopp's Avatar
Okey, thanks for answear. Its a 440.
But are there one controll unit for the injection and one for the ignition? And where can i find them in the car?
Thanks again.
Old May 13, 2008 | 01:28 PM
The control unit for the ignition is the same for both engines. It is in the engine compartment attached to the bulkhead (firewall) and has the ignition coil, again same for both engines,fastened to it.
The Engine Control Module on the 1.8 is under the right hand fascia. For some reason, knownonly toVolvo, the ECM on the 2.0 is behind the right hand kick panel.
dbnawell
Aug 23, 2012 04:47 PM
makaveli2k
Aug 8, 2012 12:32 PM
antfuentes87
Aug 18, 2011 04:13 PM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
