1994 Volvo 850 seden stereo wiring *Questions*
Hi, I'm trying to figure out what each wire is that plugs into the back of the stereo is, it's not the normal yellow for constant, red for Acc. and black for ground, it's all different.
the wiring diagrams I find say it should be: Constant: Yellow Acc.: Red Ground: Black Illumination: Orange Front Door Speakers: Left + Blue/yellow Left - White Right + Gray/white Right- Gray Rear deck Speakers: Left + Yellow/Brown Left - Yellow/Green Right + Green/brown Right - Green None of these wires appear. the previous owner had a multi-disc Cd player installed and there's a little box tucked behind the radio that has the standard Yellow, Red and Black wires running from it and the person who installed it tapped into the stock stereo wires and from what I can figure it's as this Constant: Red/Black Acc. Yellow/Black Ground: Black There's 3 solid black wires running into the plug, I don't understand it, I can't find an accurate diagram anywhere, can you guys Please direct me in the right direction? Thanks guys. |
Can you post some pics?
If you can I can try to help |
sorry for such a late reply but yeah I'll try and take some pics. thanks for tryin to help!
What kind of head unit?
I have the same problem as Jesse94. I'm needing to replace the stock stereo that is in my daughter's 1996 850 GLT.
The wiring diagrams I can find say: Constant: Yellow Acc.: Red Ground: Black Illumination: Orange There's no solid yellow wire, there's no solid red wire, there are 3 black wires. The stereo has a cd player, a casette player, and a amp, all as one unit. There are two wiring harness' The colors for the speakers don't see to lineup with what I can find either. Thanks in advance for any help. |
