Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
1998 S70 Rear Speaker and other issues.
Old May 6, 2010 | 10:26 PM
alecw81's Avatar
Default 1998 S70 Rear Speaker and other issues.
I've been reading through several threads and forums about the issues with replacing the rear-shelf speakers in our S70s.
I understand that the factory speakers are rated at 8ohms, since both the rear-shelf and rear-door speakers are running off the same 2 channels from the stock amp.
What if one were to simply disconnect the rear-door speakers (which you really can't hear from the front given their location), and then had new wires run to the rear from the amp?
Those would then be rated at 4ohms correct?
I ask, because I've found some 8" 3-way speakers rated at 4ohms on Ebay for a shade over $50. They aren't the nicest in the World, but I'd imagine they'd be an upgrade over the cruddy paper-cone OEM speakers.
Currently I have 1 blown speaker in the rear, and also a blown speaker in the front door. So I'm just considering replacing the rears as mentioned above, and replacing my 2 front door speakers with some 6.5" Polk's from my old car stereo. Would I be running into an issue up front with power? i.e. are the front door speakers rated at 8ohm as well, or 4ohms?
My 2nd idea, is to replace everything. I have 4 6.5" Polks from my old car that are more than adequate, as well as a nice 12" sub in a sealed enclosure.
EXACTLY what should I be looking for to replace the head unit, dash speakers, and rear-deck speakers?
I'm assuming the head unit would need at least 6 channels of Pre-Amp outputs, possibly 8, to power all 8 speakers and the sub.
I used to know a bit more about car stereos, but I haven't been keeping up.
Old May 7, 2010 | 12:32 PM
mkc70's Avatar
Any of your speaker scenarios should be fine, just a matter of preference or ease of install. More pre amp outputs is nice for flexibility, but not a necessity since the signal can be split to accommodate system expansion.
Old May 26, 2010 | 08:02 AM
jacks2028's Avatar
Your given idea too good using this idea we can provide a better result for speaker. This scenarios should be fine for each car models. And we get more channels for listening.
Old Oct 27, 2010 | 03:21 PM
alecw81's Avatar
Was that supposed to be English?
I'm piecing together a system right now, using the aforementioned Polk 6.5s in the rear doors, 6.5" shallow mount mid-bass drivers in the front, 8" mid-bass drivers in the rear deck, and 3.5" tweeters up in the dash. Perhaps I'll still use the 12" sub I have in the trunk as well, it will depend on the sound without it.
I've also sourced a nice amp to power everything.
Still looking for the right head-unit, considering one with built in Navigation.
Why the vagueness of the actual parts I'd use? They're rare and I don't want you jackals snatching them before I can.
Old Nov 14, 2010 | 03:04 PM
alecw81's Avatar
Still looking for a head-unit. I'd love to find one that will allow me to run 8 speakers and a sub w/o splicing anything.
Anybody have a good suggestion?
TobieRoodriguez
Apr 16, 2012 07:04 PM
SamTheMailman
Mar 18, 2012 06:23 AM
srhpunk26
Nov 14, 2011 07:16 PM
Beebe
Aug 4, 2011 03:46 PM
RSchramm
May 17, 2011 05:07 PM
