Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2004 S60 Sub/Amp
Old Apr 29, 2008 | 10:52 AM
matthiasfan's Avatar
Default 2004 S60 Sub/Amp
I have a 2004 S60 with the Hu-613, but with premium sound. I want to install a Kicker sub, and a Houston Auctustics amp. Is there a write up on how this is done? I've searched before and could not find it. This will be my first time trying to install a sub and amp into a Volvo, so is there anything to look out for?
Any help would be appreciated!
Old May 24, 2008 | 08:17 AM
green850's Avatar
Default RE: 2004 S60 Sub/Amp
well if you are going with a sub and amp, i would go ahead and replace the head unit as well.
i'm assuming you are installing a mono amp (meaning it will just be powering your sub), then go to your local best buy and pick up a wiring kit for about 50$
then you need a wire from the pos. terminal of your battery to the amp, RCA from your head unit to your amp, ignition wire from head unit to amp, ground cable from your amp to a grounded source, and then wires from your amp to you sub. the hardest part is getting to the battery, the rest is pretty easy.
good luck, if you have any questions feel free to ask
Old May 28, 2008 | 11:44 PM
DragoV70's Avatar
Have you heard of interactive signal processors? Alpine and rockford make unique signal processors which will link directly to your factory head unit and allow you to connect multiple amps and speakers without replacing your HU. Rockford Fosgate makes two versions, the 3sixty.1 and 3sixty.2:
http://rockfordfosgate.com/products/...p;locale=en_US
The 3sixty requires a PDA or smart phone to set up and operate. Very cool.
The Alpine version is less high techand a little cheaper depending on where you look,but just as effective.
http://www.alpine-usa.com/US-en/prod...model=PXE-H650
Good luck.
aben132
Nov 12, 2014 10:03 AM
JackyOC
Jun 25, 2014 11:25 PM
Weezy1010
Feb 25, 2011 04:38 AM
Colinf4
Oct 26, 2010 08:17 AM
swedes60
Jan 27, 2009 02:16 PM
