Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Electrical system failure
Old Aug 5, 2011 | 08:54 AM
Ray Cousineau's Avatar
Default Electrical system failure
My 2005 XC90 has lost all instrument guages, power windows, climate control, interor lights. Headlights, power seats, turn signals still work. Car starts fine and runs with no problems. It appears to be a partial failure of the electrical system. I checked all fuses and they are ok.
The car is in for repair now - but the mechanics are "stumped".
Any suggestions?
Old Aug 21, 2011 | 05:42 PM
markfry21's Avatar
It's the main control board. Same thing happened to my s60. Took The dealer a week to figure it out. Would happened when outside temps rise above 95 ..but replacing board has solved problem. Spendy..
Old Sep 12, 2011 | 10:45 AM
idlemind1999's Avatar
Any update on this? I hope you got it sorted out.
Old Sep 13, 2011 | 06:11 AM
Default Electrical System Failure
Problem solved! At least, temporarily - mechanic cleaned a main wiring harness and the system came back on line.
However, radio/cd player only works when the outside temp is below 50 degrees (C)
Old Sep 19, 2011 | 05:16 PM
Originally Posted by ray cousineau
problem solved! At least, temporarily - mechanic cleaned a main wiring harness and the system came back on line.
However, radio/cd player only works when the outside temp is below 50 degrees (c)
cleaned???
Old Sep 20, 2011 | 05:36 AM
Default cleaned ???
The mechanic told me he cleaned the electrical contacts - and when he reconnected the wiring harness the system came back on line
Old May 29, 2012 | 04:30 PM
markotheflorist's Avatar
did you have the problem again??
Old May 30, 2012 | 05:51 AM
Yes - about 4 weeks later the entire system shut down again. Went back to the shop - the Mech found a bad ground wire connection in the running board on the driver side. Fixed it again.
I traded the Volvo in last November - best move I made all year. No more worries.
Old Nov 1, 2012 | 08:42 AM
SabinAzaia's Avatar
Old Dec 7, 2012 | 01:21 AM
Lowarencioyo's Avatar
It's the main management panel. Same thing occurred to my s60. Took The supplier per weeks time to determine it out. Would occurred when outside temperature increase above 95 ..but changing panel has fixed problem.
mcnaught82
Feb 14, 2019 07:02 PM
jasonthaynes
Dec 2, 2012 05:32 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
