Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
How to modify the car audio player power wire so that always ON?
Old Apr 6, 2012 | 12:39 PM
sponnerjhon's Avatar
Default How to modify the car audio player power wire so that always ON?
Hi, i have an old car audio player and i wish to modify it so that i can use the power supply from my room power socket and listen in my room. But i check the wire, there are red and yellow. Which one i should connect to the +12V?
Old Apr 11, 2012 | 03:16 PM
v40pongo's Avatar
erh, dont nail me on it but i believe on normal ways the yellow is the ignition connection, the red one the permnanent +.
is there a black or blue one as well?
Old Apr 12, 2012 | 08:16 PM
tomecsi's Avatar
Yes, red is constant power, yellow is antenna/ignition and black or sometimes green is ground. Wouldnt you be better off just buying a home stereo? lol
Old Apr 29, 2012 | 02:58 AM
Brick850's Avatar
If you want it to work all the time, you need to connect + to both wires, the ignition one will make it work, the batt wire will enable it to keep it's memory.
Old Nov 1, 2012 | 08:41 AM
SabinAzaia's Avatar
Red is constant power, yellow is antenna/ignition and black or sometimes green is ground.
Ghirardelli
Oct 18, 2009 07:10 AM
shadow
Jan 19, 2009 12:08 PM
bigern45
Jul 8, 2008 09:35 PM
BigAdam
Jun 30, 2008 04:23 AM
Sportvolv
Oct 9, 2006 07:59 PM
