LED LIGHTS
RE: LED LIGHTS
I was thinking of trying some of the new 13 watt LED bulbs coming out of China. Hopefully that'll be close enough to the original 21 to not trigger bulb failure warnings. Hopefully they won't blink too fast, too.
13 watt LEDs from Hong Kong
Dimensions are same as original so I'm sure it'll fit through those small holes anyways.
RE: LED LIGHTS
One of my high beams was near burned out and half as bright as the other, and it didn't trigger a bulb out alarm until it went completely dead, so I think it'll probably work without a load balancer. But all that energy has to go somewhere, if not heat then it must be all light.
RE: LED LIGHTS
I picked up some 55W backup lights from pep boys a few years ago. I was skeptical about putting a 55w bulb in there, but tried it out. Had them in my S80 for nearly two years, and just bought a set for my V70. They're pretty bright to say the least, and as far as the 55w bulb putting out tons of heat, I checked for heat damage after a few weeks on both vehicles and saw no effects. If you drive a lot at night these are a MUST!
They look sorta like these: http://www.chevsofthe40s.com/detail/11498.html
The ones I bought have a ceramic insulator at the base of the bulb, I am assuming to help with heat. They were only $9/ea.
95 850 GLt Sedan, LED/HID succes
For the rear tail lights, I used the BA15 24-LED. Choose 1156 Red, Wide Angle. These are brighter, but not insanely so, than the original light bulbs.
For the brake lights, I used the BA15 5-Watt LED Bulb. Choose Red. Definitely brighter than stock bulbs.
I'm not happy with the BA15 24-LED in the center Stop light, because the housing's bulb base is at an angle, which makes the light darker on one side. I'm going to replace that with a small circuit board full of LEDs that will mount flush to the lens inside the light fixture.
I have no bulb warning failures. I tested my LED bulbs in the turn signals, and got no bulb failure warning, except for the fast-flashing.
Between the LEDs and HID lights I installed, I have reduced my electrical load by about 60 watts, or 10% of alternator output. I haven't measured it, but any electrical load reduction must help prolong the life of alternator and battery. If nothing else, it makes up for iPod, BlackBerry chargers.
I got lazy, and didn't want to mess with the flashers, so my turn indicators are still incandescent. But, In a Ford Escort, I had replaced the flasher with a LED-ready electronic Flasher. That was to prevent the fast flashing. LED turn signals work with your stock flasher, but you get the rapid blinking.
On a related note, I install an aftermarket HID kit for the low-beams into the stock headlights. This doesn't look at cool as projector beam lights, but from the drivers seat, the visibility is incredible. The HID lights really pick up signs from farther away, I can see street signs in residential neighborhoods without stopping to read them. The best benefit in the increased illumination of reflective devices is the word "police" that now glows from farther away as I approach speed traps. I'm quite please with how well the HID lights work in the rain, snow, etc.
If you install aftermarket HID headlights, you may want to lower the beams to compensate for the wider pattern. The HID lights act more like a flood light, and eliminated my desire to install fog lights.
For the high-beam, I cheated, I used the Silvania "cool blue" bulbs. I live in the city, high-beams are for letting oncoming drivers know one of two things: your brights are on, or, you're going to pass a speed trap.
If I lived in the country, I would go for HID high beam lights as well.
About LED colors:
Everyone probably knows this, but LED lights should be chosen to the color of their application. Using a White light will be dim in a red or amber lens, because your filtering out unwanted colors of light. To put it another way, colored LED's direct all their energy to producing exactly the color light you need. That is why they are great for indicators on cards.
autolampsplus
09-27-2008 01:41 PM
autolampsplus
12-18-2006 01:42 PM
