Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
Brake suddently stop working after collision
Old Oct 17, 2023 | 06:56 PM
CarMaster's Avatar
Default Brake suddently stop working after collision
Hey Volvo community,
I have a question that has been bothering for quite a while.
I had a Volvo Xc 60 that was purchased almost 10 years ago. I was driving on a highway and got hit by a trunk, which then surpassed me from the left lane. After the collision, the air bags on the left side came out and then the brake suddenly stop working. I cannot slow down the car at all. I also smelled something burning.
I hope someone here, especially mechanics, can help me understand how the brake stopped working. I had my last check-up/maintenance a week before the collision.
Thanks a lot in advance!
Old Oct 19, 2023 | 11:49 AM
sounds like something mechanical ie the master cylinder, or more likely a hose got damaged fluid leaks/hoses have let air into the system. How does the pedal feel? Does it pump up after 4-5 fast foot pumps?
Brakes are still 90% mechanical systems - if you lose the ABS system, brakes still work unless a valve in the distrubutor is stuck - and that will only impact one pair of wheels. If you loose the vacuum booster, brakes still work - just a firm pedal that tests your leg strength. Low fluid should be easy to spot (open reservoir cap), check for leaks and mechanical damage to lines.
To further the diagnosis you may need to start opening lines - I'd start with a buddy to pump the brakes while checking each caliper for action. then I'd bleed the brakes - starting with the rears to see if any fluid/air comes out with each foot pump. If no action on the rear brakes, then you'd move up to the ABS valve body to see if fluid is getting from the master to the ABS. You can also try bleeding the master to see if that has any pumping action.
The something burning is likely a caliper that is stuck closed. That could be the caliper or could be there is no path for the fluid to return back to the master (crimped line? defective master or proportioning valve or abs valve body). Did you happen to slam on the brakes during the collision?
Columba
Sep 4, 2023 08:28 PM
good1662
Dec 26, 2014 12:39 AM
tiny44
Jan 17, 2010 06:59 PM
HTRD2B
Jul 19, 2009 12:10 AM
