Detailing Discuss detailing your ride inside and out here.
Sticky Window / Door lock Buttons
Old Aug 11, 2008 | 01:36 PM
MoodsR4Cattle's Avatar
Default Sticky Window / Door lock Buttons
Hello!
I have recently purchased a 2000 V70 and all the window / door lock buttons are black and sticky. I have tried everything to clean them, including scraping them with my fingernails, but I can't seem to get all the goo off. Do you have any suggestions?
I hope I've posted this in the right section, my apologies if I have goofed.
Thanks!
Moods
Old Aug 12, 2008 | 05:56 AM
SACS80's Avatar
Default RE: Sticky Window / Door lock Buttons
If it is not too bad try using straight IPA. If you have any leather nearby make sure you cover it.
Old Aug 12, 2008 | 05:58 AM
SACS80's Avatar
If that does not work try amonia and water. (1:5)
Old Aug 12, 2008 | 07:34 AM
Thanks, SACS80. What is IPA?
Yes, the buttons are very sticky, I couldn't even see the lights underneath!
I'll try the ammonia and water solution.
Old Aug 13, 2008 | 12:45 AM
SACS80's Avatar
"Rubbing Alcohol" or formally "Isopropyl Rubbing Alcohol".
Go to you local drug store pick up a few bottles. I use for everything. Good for windows, ***** and allot more. Just make sure to protect any leather with a thick old towel. It will remove the top coat on the leather and damage the color.
I keep a small spray bottle in the truck. Half water, Half IPA.
Old Aug 13, 2008 | 10:49 AM
Ok, thanks ... I actually have some of that around here ... somewhere ...
Will try that too!
mercb
Oct 21, 2009 12:53 PM
steved
Dec 20, 2008 05:37 PM
bulldog
Dec 15, 2008 07:24 AM
mayday_v
Aug 24, 2008 08:57 PM
dmandpe
Aug 23, 2008 09:09 PM
