Detailing Discuss detailing your ride inside and out here.
Wheels & Tires How To - PinnacleWax.com
Old Oct 27, 2014 | 06:15 PM
PinnacleWax's Avatar
Former Sponsor
Default Wheels & Tires How To - PinnacleWax.com
Detailing Wheels & Tires
Clean wheels and dark tires start with a water-based wheel cleaner and a long-lasting tire protectant. You can find them both at Pinnacle.
Wheels and tires are subject to grueling conditions as heat, grease and grime, and friction all take their toll. We place heavy demands on our wheels and tires but they can still look good if you use Pinnacle's wheel and tire care products, including Pinnacle Advanced Wheel Cleaner Concentrate and Pinnacle Black Onyx Tire Dressing.
The first priority with wheel care is removing brake dust. Brake dust is a corrosive mixture of carbon fibers and adhesive from the brake pad plus metal shavings from the rotor. This sticky mixture clings to the wheel and bakes there as the braking system produces heat and friction. If brake dust is left on the wheels too long, it can eat through wheel coatings and even pit metal. Regular wheel cleaning with Pinnacle Advanced Wheel Cleaner Concentrate is your best defense.
The number one offender of tires is the sun, but a close second is sub-par tire dressings. Tire dressings that are loaded with silicone actually turn tires brown over time and dry out the rubber. To safeguard your tires against premature aging and discoloration, use Pinnacle Black Onyx Tire Dressing.
Start at the bottom
Always clean the wheels and tires before washing your vehicle. This will prevent overspray or grime from splashing onto already-clean panels. If you like to clean your wheels and tires with soap and water, use a separate wash and rinse bucket from the one you intend to use on the paint. Wheels and tires are the dirtiest part of your vehicle and nothing that touches them should touch the paint.
Step 1:
Choose a water-based wheel cleaner that is appropriate for all types of wheels. Roughcast aluminum and chrome can withstand stronger cleaners than coated, painted, or anodized wheels. Use Pinnacle Advanced Wheel Cleaner Concentrate to eliminate the guesswork.
Pinnacle Advanced Wheel Cleaner Concentrate is water-based and non-caustic. It changes colors as it cleans your wheels! Pinnacle Advanced Wheel Cleaner Concentrate even removes brake embedded dust that has crept into tiny holes in the metal. A little agitation with a brush will allow Pinnacle to work even better.
Step 2:
When selecting a wheel brush, look for a brush with feathered bristles to prevent scratching. The Montana Original Boar's Hair Wheel Brush is a very soft brush. For spoked wheels, use the Daytona Speed Master Wheel Brush for unbeatable access to the wheels' slots. It also has soft bristles and a flexible stem to reach behind spokes.
Tires require a stiffer brush to really penetrate rubber's pores. The Contour Tire Brush has stiffer bristles with a curved head to match the curvature of the tire. Use it to scrub off old layers of dressings and road grime. When you apply Pinnacle Black Onyx Tire Dressing, it will bond better with clean rubber.
Step 3:
Always dry your wheels! Use a microfiber towel, but not one that you plan to use on any other part of your vehicle. Once a towel is used on the tires or wheels, it should always be designated for tires and wheels. Drying prevents water spots and helps you remove every last bit of the brake dust.
Wax your wheels!
Wheels can be waxed just like the paint. Waxing the wheels will reduce brake dust accumulation and allow moisture to roll off. Once your wheels are clean and dry, apply Pinnacle Liquid Souverän Wax. It lasts for months and it creates a very slick finish. Apply the wax with an applicator pad and then buff the wheel. Your wheels will look cleaner longer.
Dress for Success
Once your wheels are clean, shiny and sealed, you must protect the tires. Choose a tire dressing without silicone, like Pinnacle Black Onyx Tire Dressing. As we discussed earlier, silicone dries out rubber by depleting its own protectants prematurely. Over time, tires will turn brown. To avoid this fate, use only water-based Pinnacle Black Onyx Tire Dressing.
Pinnacle Black Onyx Tire Dressing has a satin shine that looks more like new, healthy rubber. It's understated and elegant. Most importantly, it doesn't attract dust like silicone dressings and it doesn't dry out the rubber. Your tires will look fresh, supple, and hydrated. UV protectants prevent fading. Always apply thin coats of Pinnacle Black Onyx Tire Dressing to prevent sling. Multiple thin coats will bond better to the tire and last longer.
A complete wheel and tire care kit is available in the Pinnacle Concours Wheel & Tire Kit! Check our Tire & Wheel Care Page for more excellent tire and wheel brushes and tools.
Any questions, just ask! Thanks For Looking!
garydrenk
Oct 31, 2011 08:00 AM
garydrenk
Sep 18, 2010 12:05 PM
garydrenk
Sep 18, 2010 12:02 PM
garydrenk
Sep 18, 2010 11:57 AM
