Engine & Internal Chat about beefing up your insides here.
Oil pouring from tailpipe
Old Jan 28, 2020 | 02:12 PM
Millbob's Avatar
Default Oil pouring from tailpipe
Purchased a 2006 S80 with turbo for my kids in October. The car recently became due for an oil change but ran great. Took it in for an oil change yesterday. On the way home smoke started coming from the tailpipe. Got out and checked under the hood. No smoke coming from under the hood, checked the dipstick, it had clean oil on it. Luckily I was less than a mile from home. Got it home and let it run in. The driveway to see if the smoke (only smoke) would go away. The thought was that maybe the previous owner used standard oil instead of synthetic oil. And it was smoking because of the new synthetic oil. Checked the oil again (on a level surface) and the dipstick was bone dry. Added more oil and called it a night. Today I went to start the car, after making sure there was oil on the dipstick. There was oil but just a bit on the tip. So I slowly added enough to safely start the engine. After staring it right up, along with smoke, oil is litterally pouring out of the tailpipe! It is definitely oil (smells, feels and looks like oil). None of the other fluids are low, the "no oil pressure, stop safely" light flickers on occasionaly, otherwise no idiot lights and the gauges read normally. The car starts, runs and drove normally. When the oil level drops back down there is the obvious engine noise.
Has anyone EVER seen this?
Oil coming from tailpipe!
Old Apr 7, 2020 | 01:32 AM
Millbob's Avatar
I dont believe I can safely do a compression test. The car does appear to have all the symptoms of a bad turbo. BUT the spark plugs all have normal wear, except the spark plug on cylinder 3 (the middle one). It was pretty covered in oil. Aside from the turbo, is there any other place that would allow oil to dump into the exhaust?
Millbob's Avatar
Millbob
Apr 12, 2023 03:32 PM
forevertwiztid45
Oct 18, 2014 05:11 AM
Msuperbauer
Jul 1, 2012 06:39 AM
yoyoman
Nov 3, 2011 05:00 PM
bigern45
Aug 27, 2008 08:04 PM
