Forum Issues Discuss any issues you are having with the forums here.
2002 v70 engine oil leak
Old Nov 29, 2014 | 07:37 PM
PaulL70's Avatar
Default 2002 v70 engine oil leak
'02 V70 has engine oil leak which appears to be coming from lower part of timing case area. it is definately coming from somewhere about half way up the engine above the harmonic balancer. any ideas of common oil leaks from this area? 2.5L turbo model. there is also a slight oil leak from turbo area but that is separate. 3rd issue i have is the transmission responds slowly engaging once it is put into drive. the car has 140,000 miles. thank you to any who might be able to assist. Paul
Old Nov 29, 2014 | 11:51 PM
ES6T's Avatar
Cam seals. Possibly due to clogged PCV system.
joshuapfitzpatrick
Jun 25, 2012 10:57 AM
bobloftus
Jun 26, 2010 02:06 PM
illfrom
Mar 7, 2010 09:15 AM
markm
Mar 13, 2008 07:46 PM
