Starting problems 2008 V70 3.2
Generally when I open the drivers door I can hear what sounds like the power brake vacuum pump charge the brake system. When I hear that sound I can insert the key fob and hit the start button and the car starts.
Sometimes I don't hear that sound. When that happens I insert the keyfob step on the brake and the display goes blank or the start button does nothing.
I take out the key fob and try the start sequence over and over. Eventually the car will start. I was told before to replace the brake light switch, which I did. The problem still exists.
The start sequence is, step on the brake, insert the keyfob, hit the start button. The warning lights light up and the car starts.
fcpgroton
Mar 13, 2012 02:11 PM
