Forum Issues Discuss any issues you are having with the forums here.
Volvo C30 Timing Chain timing
Old Dec 24, 2020 | 12:08 AM
Thomas Justin Van Deventer's Avatar
Default Volvo C30 Timing Chain timing
ive replaced my piston rings . ive now discovered that the crank pulley timing was thrown out too .so piston and valve are touching does any one know where i can find thew timing marks on the volvo
its the 2L engine petrol
Old Dec 24, 2020 | 12:39 PM
when you say you've replaced the rings, can we assume you've completely removed the head from the block and are in the process of reassembling? You didn't note the year/engine code but assuming its a standard T5, you'll find the crank timing mark on the pulley and a mark on the block. With the head off you should have set the #1 to TDC manually then checked for the timing mark to make sure you're not 180 off. The cams are marked on the back end and the VVT gears need to be rotated to match the spec.
See if this link helps. Setting the crank/cam/VVT timing on your rebuild would be the same as when replacing the timing belt so you should be able to find stuff on the net or vids on Youtube.
https://www.pelicanparts.com/techart...eplacement.htm
Old Dec 24, 2020 | 01:15 PM
I have discovered how to set the Pistons through the guide whole by the camshaft. My Volvo has 2 standard camshafts so no vvt. There doesn't seem to be any marking on the cams does anyone know if there are. As far as I know I could be out but not sure how to set them. I know there is a guide in the back but due to removing them they could be 180 out
Stan Mosler
Forum Issues
Aug 17, 2014 06:02 AM
rspi
Feb 27, 2013 01:10 PM
rspi
Jul 11, 2010 12:48 AM
