08 XC70 climate control interchangeable?
Old Feb 28, 2024 | 07:58 PM
Kevncat22's Avatar
Question 08 XC70 climate control interchangeable?
i just purchased 08 XC70, the stereo and climate control dont work and we have checked the fuses and the wires, all seems to be good so looking into purchasing one off bay. My question is what numbers need to match in order for me to plug it in and it work? i dont want to have to reprogram it after i get it.
Old Feb 29, 2024 | 08:50 AM
xemodex.com might know if used climate modules would be plug and play.
But you should use a compatible scanner to talk to all the control units before randomly replacing parts. It's always best to diagnose before replacing stuff you don't need.
For instance - if there's a connection problem in the can bus network - the CCM (climate) and ICM (infotainment ) modules are on their own "leg" of the network, and can be disconnected without causing problems in the network. Those systems won't work if there's a connection problem in the network wires. (below is just the can network portion, the rest of the wiring is on other pages) Wiring diagrams can be found at volvodiag.com
lisaj
Jan 25, 2023 08:27 AM
VolvoPatrick
2001-2013 model year XC70
Aug 21, 2022 09:10 AM
aclarke207
May 18, 2022 12:46 PM
PJ5670
Apr 20, 2018 06:31 AM
evergreen123
Jul 3, 2011 03:06 PM
