1997 Volvo S90 window switch
Hello all. I have an issue with my driver window going down, but not back up. I took out the switch and cleaned it with contact cleaner, but still the same problem. The connector and switch is a bit loose whereas the other switches and connecters are snug. It goes down but not back up. Switch or connector?
Thanks! |
best to replace the switch. Check out Tascaparts.com for dealer part #s and pricing.
Originally Posted by mt6127
(Post 463018)
I replaced the switch and it worked once to power the window back up as it was stuck down. Now it won't move at all, all other windows work from master switch. All I hear is a click coming from the relay when drivers window is pressed. Is this relay only for the drivers window? Most likely bad relay? Thanks
Try holding the button in the up position for 20 seconds. Sometimes a reset is necessary.
Originally Posted by tony1963
(Post 463460)
