1997 Volvo S90 window switch
Old Jul 26, 2018 | 02:35 PM
anotherbrickindastreet's Avatar
Default 1997 Volvo S90 window switch
Hello all. I have an issue with my driver window going down, but not back up. I took out the switch and cleaned it with contact cleaner, but still the same problem. The connector and switch is a bit loose whereas the other switches and connecters are snug. It goes down but not back up. Switch or connector?
Thanks!
Old Jul 27, 2018 | 04:24 PM
best to replace the switch. Check out Tascaparts.com for dealer part #s and pricing.
Old Jul 27, 2018 | 05:18 PM
Thanks for the reference. I'll try it out.
Old Aug 3, 2018 | 03:26 PM
I replaced the switch and it worked once to power the window back up as it was stuck down. Now it won't move at all, all other windows work from master switch. All I hear is a click coming from the relay when drivers window is pressed. Is this relay only for the drivers window? Most likely bad relay? Thanks
Old Aug 3, 2018 | 03:49 PM
tony1963's Avatar
Try holding the button in the up position for 20 seconds. Sometimes a reset is necessary.
Old Aug 3, 2018 | 09:47 PM
Thanks for the info. I tried it twice...no luck. Same click.
Aug 8, 2018 05:51 PM
menguchita
May 29, 2009 08:50 PM
rzskier
Jun 26, 2008 12:57 AM
hubmachine
Jun 21, 2006 11:33 PM
bigld
Jan 2, 2006 08:52 PM
