20 inch rim options
i am looking to put 20 inch rims on my 2016 xc60. Would 20 inch rims from a 2012 xc90 fit? I am being told they would by the seller but would like to be sure.
the size of the rim is not the concern - the fit is based on bolt pattern, center bore and offset. Both the cars list out as 5x108 for the bolts, 63.4mm bore and a 55mm offset. Sounds like you'd be good to go, using a 255/45R20 tire... but you can do your own research, plenty of links like PCD Volvo wheels -Wheelfitment.eu | PCD, Offset, Center Bore, mounting and tire size data
Great info. Thank you.
G
Originally Posted by mt6127
(Post 454673)
the size of the rim is not the concern - the fit is based on bolt pattern, center bore and offset. Both the cars list out as 5x108 for the bolts, 63.4mm bore and a 55mm offset. Sounds like you'd be good to go, using a 255/45R20 tire... but you can do your own research, plenty of links like PCD Volvo wheels -Wheelfitment.eu PCD, Offset, Center Bore, mounting and tire size data
