20 inch rim options
Old Dec 26, 2017 | 08:28 PM
GuyA's Avatar
Default 20 inch rim options
i am looking to put 20 inch rims on my 2016 xc60. Would 20 inch rims from a 2012 xc90 fit? I am being told they would by the seller but would like to be sure.
Old Dec 26, 2017 | 08:48 PM
the size of the rim is not the concern - the fit is based on bolt pattern, center bore and offset. Both the cars list out as 5x108 for the bolts, 63.4mm bore and a 55mm offset. Sounds like you'd be good to go, using a 255/45R20 tire... but you can do your own research, plenty of links like PCD Volvo wheels -Wheelfitment.eu | PCD, Offset, Center Bore, mounting and tire size data
Old Dec 26, 2017 | 09:07 PM
GuyA's Avatar
Great info. Thank you.
G
Originally Posted by mt6127
the size of the rim is not the concern - the fit is based on bolt pattern, center bore and offset. Both the cars list out as 5x108 for the bolts, 63.4mm bore and a 55mm offset. Sounds like you'd be good to go, using a 255/45R20 tire... but you can do your own research, plenty of links like PCD Volvo wheels -Wheelfitment.eu PCD, Offset, Center Bore, mounting and tire size data
shuvav
Jul 10, 2012 01:02 PM
Bruno
Mar 28, 2006 09:22 PM
medufour
Nov 19, 2005 01:35 PM
brushfires60
Jun 15, 2005 12:27 AM
rAcing_VoLvOs
Mar 12, 2004 12:41 AM
