2003 S40 1.9 All symptoms point to temp control sensor. but not.
Old Jul 23, 2018 | 01:32 PM
Barry51's Avatar
Default 2003 S40 1.9 All symptoms point to temp control sensor. but not.
Hi. wondering if anyone can help. 1- cooling fan works but does not turn on when hot. 2- cooling fan sometimes turns on when cold just when key is on and then for a little while. 3- engine surges. 4- will not restart or very hard to start after engine running for a while. Temperature gauge erratic. jumps to hot for a second or two when cold then registers cold when engine is hot.
Cooling system is full. Thermostat is opening. Changed the temp control sensor. Fans work when A/C turned on. No check engine light coming on and no codes.checked plug connectors.
I dont where to go next...Anybody???
Old Jul 23, 2018 | 07:08 PM
I saw a similar post in the S40 section - I can merge or delete this one. you may also find some insights at volvowiringdiagrams.com
2000 volvo c70
Jun 1, 2020 04:52 PM
Adrian Snare
Oct 4, 2019 08:20 PM
Barry51
Jul 26, 2018 11:02 AM
Czakky
Jul 21, 2015 05:45 PM
Orionflyn
Jun 6, 2013 09:09 AM
