940 Windscreen washers not working
Hi,
I've got a problem with my 1991 940 washers. At first I thought it may be the motors so I've just replaced them, I get water to the rear washer but not the front. I’m unsure now whether I've reconnected the hoses in the correct way as I seem to have excess hoses. I've simply traced the hose which leads to the fronts washers back to the reservoir and then connected it to the larger of the two washer motors, is this incorrect in some way? Can any one offer any suggestions? |
Are the sprayers clogged? This does happen somethimes. I use a normal / stripped garbage tie to clean them out.
