940 Windscreen washers not working
Old Jun 13, 2009 | 12:14 PM
Psy's Avatar
Psy
Default 940 Windscreen washers not working
Hi,
I've got a problem with my 1991 940 washers. At first I thought it may be the motors so I've just replaced them, I get water to the rear washer but not the front. I’m unsure now whether I've reconnected the hoses in the correct way as I seem to have excess hoses. I've simply traced the hose which leads to the fronts washers back to the reservoir and then connected it to the larger of the two washer motors, is this incorrect in some way? Can any one offer any suggestions?
Old Jun 14, 2009 | 10:29 AM
Are the sprayers clogged? This does happen somethimes. I use a normal / stripped garbage tie to clean them out.
Andima1981
Oct 30, 2014 03:13 AM
rspi
May 15, 2014 07:36 AM
lesk
Oct 1, 2011 08:51 AM
BigAdam
Oct 21, 2008 10:01 AM
