96 850 No heat in the dead of winter? AHHH!
Old Jan 12, 2009 | 02:32 PM
Angie's Avatar
Default 96 850 No heat in the dead of winter? AHHH!
I just got my Volvo a few months ago at the beginning of winter. I have had heat and defrost until just the other day. When I put the heater on there is a little bit of a sound...maybe like a motor trying to do something, it is very faint. The heat does not come on at all though. No heat, no defrost, no comfort...yuk![:'(] There is no fan. When I drive on the highway, after a while,a bit ofheat will come through the vents, but it is not being pushed through by a fan or anything. As soon as I slow down the heat is gone again. Has anyone had this happen. I read some other forums similar and think I have a pretty good idea about what needs to be done. I just wanted to ask for your advice as well. Thanks I look forward to what you have to say.
~Angie
Old Jan 12, 2009 | 02:47 PM
Joshbaldwin's Avatar
Default RE: 96 850 No heat in the dead of winter? AHHH!
Angie, The first thing I would check would be your fuse panel. The fan should be working with or without heat. I also would think your heater should operate when the fresh/recycle switch is on fresh air. If not Heat hose's?, Heatercore? I just start with the fuse box.
Old Jan 12, 2009 | 04:57 PM
My vote is blower motor and or resistor. They are very common to go bad.
Old Jan 18, 2009 | 11:01 AM
joseph17257's Avatar
I just had the same issue last month with my 850. It turned out to be the blower resister behind the glove box. I got a used one from a junk yard for $20. It probaly takes about 30 minutes to replace.
murphysmotors
Jan 21, 2021 06:52 PM
Noobed
2001-2013 model year V70
Jul 6, 2012 01:35 PM
nucguy
Oct 11, 2011 08:40 PM
Fuddy Duddy
Mar 24, 2011 05:37 AM
jbachus
Aug 22, 2009 07:34 AM
