air/fuel gauge install
Old Feb 23, 2012 | 07:36 PM
nitrosport's Avatar
Default air/fuel gauge install
tips is what I need.
I bought a generic air/fuel ratio gauge for my 95 850 turbo.
I know these get readings from o2 senors...is there a way to tie the gauge into the existing o2 sensor?
If not, where should I place a new o2 sensor for the gauge?
Old Feb 23, 2012 | 09:08 PM
If it is not a wide band setup it will not help much on the 850. Yes it can be hooked up but is not really all that accurate.
Old Feb 23, 2012 | 09:32 PM
nitrosport's Avatar
It wasnt till after I bought the gauge that I notice some were narrow band and some wide band gauges.....and the 1 I bought doesnt even say on the ad which it is.
Here is the ad: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Can it be hooked up to the stock o2? And the 850 has 2 o2 sensors right? So which should it be, pre-cat or post cat?
I saw some vids on utube and noticed these gauges can move all over the place (dont seem very accurate) but figured it may give a general sense of how she is running. Plus, gauges just make the interior cooler
Ah, found the same unit in another ad...its a narrow band. I assume that wideband are more expensive/accurate.
Old Feb 25, 2012 | 06:53 AM
Yes the wide band is WAY more accurate. The narrow band in these cars are just a light show.
It can be hooked up to the front O2 if you really want to do it. I just do not remember the colors off hand of the wires.
subaruwrx10
Feb 29, 2012 09:03 PM
volvoracer91
Oct 21, 2009 12:59 PM
lorvar
Jun 4, 2007 05:31 AM
blu98t5
Engine & Internal
Sep 11, 2005 11:37 PM
