Alarming oil useage 2000 S40
Old Oct 10, 2013 | 12:46 PM
Herebrooks's Avatar
Default Alarming oil useage 2000 S40
Hi all: I had my car in the shop for a week and a half trying to find out why I was having to add oil every 200 to 400 miles. Larry( Larry's Performance werks,inc, great shop) did a leak down test followed by a chemical treatment to see if that improved the leakage of oil into the cylinders. Results were 1-70%,2-65%,3-70%-4-70%. The crankcase pressure= 0.5KPA.
My plan now is for me to change out the oil trap.
What are your thoughts? To me, the car runs well, but, as I said it's using oil at an alarming rate.
Thanks
Old Oct 10, 2013 | 01:27 PM
ES6T's Avatar
Those percentages are cylinder leakage? It would not run well, if at all, with those numbers.
Old Oct 10, 2013 | 04:48 PM
difflock54's Avatar
Have you detected any oil leaks or noticed blue smoke from your exhaust?
Old Oct 10, 2013 | 06:30 PM
Herebrooks's Avatar
Default Leak down percentages
I believe the percentages were taken from the leak down tester, There are no leaks from what I can see.
Old Oct 10, 2013 | 07:37 PM
difflock54's Avatar
Sorry, i was referring to external engine oil leaks visible or puddles on the floor when parked. Maybe oil seals, oil hoses etc.
refer link re: leak down testing.
What is a "leak down" test? — Yahoo! Autos
Greater than 30% apparently means serious problems.
Ideally about 5-10% is normal range
Old Dec 30, 2013 | 09:36 AM
urbino's Avatar
Default oil leaks
Ideally about 5-10% is normal range[/QUOTE]
Ive parked my 2000 v40 in the same spot in the garage since it was new...no leakage to date....93k odo
Old Dec 30, 2013 | 10:31 AM
What are the hard compression numbers?
Old Dec 31, 2013 | 02:48 PM
Gary Green's Avatar
Default oil usage
What mileage has she got,mine has over 300,000 and only uses about a litre between changes.
Old Jan 1, 2014 | 08:09 AM
Herebrooks's Avatar
Default Oil usage
My s40 has about 130k on it. The garage did a ring treatment tp remove sludge that might be keeping the rings from sealing properly. I've also assembled the parts to replace the "black box" and hose but haven't installed them yet. I don't notice a lack of power and we continue to drive it daily, just keeping an eye on oil consumption which is not as bad as when I first posted. I'll get into the repairs when it warms up.
Bill
aryanvahedi
Oct 8, 2014 02:26 PM
lookzshame239
Sep 5, 2012 08:31 AM
castlehotrod
Jan 24, 2011 01:50 PM
tefcaptain
Jun 24, 2010 11:56 PM
js1762
Mar 19, 2008 07:50 AM
