ARRRRRRRRGGHH HOW DO YOU TURN OFF DRIVING LIGHTS ON 1998 VOLVO V40
Old Jan 19, 2008 | 07:02 AM
markjenross's Avatar
Default ARRRRRRRRGGHH HOW DO YOU TURN OFF DRIVING LIGHTS ON 1998 VOLVO V40
CAN SOME1 PLEASE TELL ME HOW TO TURN OFF LIGHTS ON MY VOLVO V40 1998 T4.ALSO CAN YOU TURN OFF SERVICE LIGHT ALSO OR DOES IT HAVE TO GO TO DEALER.ANY HELP WOULD BE MUCH APPRECIATED.
Old Jan 19, 2008 | 08:32 AM
S70driver's Avatar
Default RE: ARRRRRRRRGGHH HOW DO YOU TURN OFF DRIVING LIGHTS ON 1998 VOLVO V40
So angry. Calm down there. No need to yell at us.
To turn off your Day Time Driving lights you....
Ok on the left hand side of the steering wheel there should be a dial to switch your headlights in three different posiitions. All the way to the left is DRL's and all the way to the right straight up is Low Beams. Turn it all the way to the left so DRL's are on. Then...
Then you should see a little slit like object. Looks like the head of a screw. You turn that. I forget which direction and your DRL's are diabled. If you don't have that then I believe it is a trip to the dealership.
Old Jan 19, 2008 | 09:33 AM
hi thanks my switch is on right as in uk
i dnt have slit like screw etc either can u not disable lights with fuse etc so dont come on wen start engine
Old Jan 19, 2008 | 09:40 AM
S70driver's Avatar
Can't answer that. I gave you the only answer I know of. Maybe someone else on the forum can help you.
Old Jan 19, 2008 | 10:48 AM
The owners manual tells you how to turn them off.
I don't know I haven't ever done it that way I have always used the laptop setup to turn them off.
Old Jan 23, 2008 | 05:07 AM
sophisticars's Avatar
Hi Markjenross it looks like a trip to the dealership! or to a good auto electrician with diagnostics my s80 came with the lights turned off i think the previous owner paid around £70 for them to be disabled. (unless you have diagnostic software your self?)
You shouldn't have to go to dealers to have service light switched off, there should be a sequence to follow to reset the light i.e key at I press odometer button till beep turn to II etc i couldn't tell you the sequence as it may be diffrent to the S80, again if you go to a agrage they will be able to switch the light out (all decent garages have a book with them all in) i will see if i can find the sequence for you, if so i'll pass it on.
Old Jan 23, 2008 | 07:44 AM
JPN's Avatar
JPN
AAARRRRRGHHH sell it!
AAARRRRRGHHHcrash it (good luck on this one)!
AAARRRRRGHHH grab your chisel & hammer!
AAARRRRRGHHH try posting this in the S/V40 forum!!!
JPN
Old Jul 1, 2008 | 08:03 AM
nickdog's Avatar
just leave them on. whats the harm in it?
Jtree5757
Feb 17, 2014 02:16 PM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
ConfusedNovice
Feb 18, 2013 06:27 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
