break stand
What is a "Break Stand"?
Your NA your not going to make much power if any unless you spend a lot of money.
1. Turbo your car.
2. Custom SuperCharge your car.
3. Engine transplant your car
4. If anything your going to want to do a manual transmission swap to handle good power. The crappy automatic wont handle it very well.
1. Turbo your car.
As I recall, a brake stand is when you lock up the brakes and spin out the tires... I've only ever seen it done with rear-wheel drive cars - I'm not sure of the details, but I assume they have a way of locking up only the front brakes...
UPDATE: from the "Urban Dictionary" (http://www.urbandictionary.com/defin...rm=brake+stand)
when you hold the brake down and press on the gas at the same time. only works on rear-wheel cars. produces a lot of smoke and tire marks on the hot top
that kid just left major marks and a lot of smoke after doing a brake stand
Yeah well in a NA it is going to be nearly impossible.
I was truly only able to smoke my tires in my 1995 850 NA when it was wet outside. I did however once break the tires loose when I accidently put the car in Neutral and didn't know it and was putting on the gas going nowhere and then slammed it into drive.
