jack stand location
Old Jun 24, 2007 | 01:54 AM
sdat1333's Avatar
Default jack stand location
would somebody be willing to tell me exactly where to put the jack/jackstands when lifting the vehicle. This is a 2001 S60. The diagram in the manual wasn't very detailed, and I just want to make sure I'm using the right points before I trust my life to a jack stand.
Old Jun 24, 2007 | 08:01 AM
Default RE: jack stand location
I always use the Triangle looking plate where the subframe meets the body in the front.
The rear there is a section that is like a round piece that sticks down from the body.
Old Jun 24, 2007 | 08:28 AM
gfreeman9mm's Avatar
I like to use that triangle plate as well. You could also try the small cylindrical metal bars on the side of the body under the black plastic under the doors. There are two right where the front and back doors meet. Look in the manual, it tells you.
LiteWait
Mar 14, 2015 07:13 PM
Phil 850
Dec 13, 2012 08:55 PM
bw77
Apr 22, 2009 08:28 PM
brianet
Aug 9, 2008 07:32 PM
luckytweaker
Engine & Internal
Jun 23, 2006 05:24 PM
