A/C R12 options?
Old Sep 30, 2014 | 03:41 PM
AT5 240GL's Avatar
Default A/C R12 options?
Going to try this here rather than the vehicle specific forums as I believe it effects any car built prior to the mid 90s.
I've got an '85 240 with the original A/C set up for R12. I'm looking for information on my options to get the A/C going again. Everything seems to work fine, it just doesn't make the air cold, so assuming it just needs a recharge. The prior owner said it quit working several years ago, but since the weather is relatively mild and he wasn't driving much anymore he just went without. It gets a bit warmer in where I live and I drive 5 days a week, so want cool air.
I've done a search and the only threads I found on this are nearly 10 years old, so thought there might be more options available than there was at that time.
Based on the other threads it sounds like I can try to source R12 (unlikely in California) or convert to 134a, which might be as easy as drain and switch or require a significant modification depending on the specifics of my model year. Also hoping that maybe between then and now an environmentally compliant R12 compatible refrigerant had become available.
Old Oct 4, 2014 | 07:52 AM
Disco2's Avatar
Here:
Enviro-Safe Refrigerants
I used this years ago in an 86 Jetta and it worked great.
cla6665
Jun 8, 2008 10:46 PM
Patdon10
Jun 3, 2007 01:24 PM
DJboozeAlot
Nov 13, 2006 06:19 PM
parrym
Sep 25, 2005 11:23 PM
TheVolvoMan
Apr 26, 2004 10:07 PM
