Check engine and oil light issues
Hello everyone this is my first post, and I just Just need a little help. I bought a 2012 Volvo 680 work the isx engine not to long ago and everything work good on it. But as I drove up a hill and I be in tenth gear(10 speed Eaton Fuller) around 1000 rpm my computer screen on my shows a oil can and then a check engine fault messages. Then when the rpm gets up to speed it goes away completely. I check the oil and the coolant levels and everything fine. The reason I checked the coolant level because it was in the shop not that long ago because I put a brand new transmission in it. The mechanic said low cool and was none of the fault code but everything else was just codes due to sensors acting up. But I tired of the beeping when I go up hills so I need a solution, PLEASE HELP.
not too many truck engines post on this board, but I'd say there's two likely causes - you could have an oil pressure sensor issue or you have an issue with your oil pump or oil scavenger. You can try replacing the oil pressure sensor but you probably need to have the oil pan dropped and inspect the intake for debris in the scavenger pick up. If nothing there, then you're probably looking at a worn oil pump. Dunno if your truck's pump has any form of electronic controls or not...
Originally Posted by mt6127
(Post 450642)
