Coolant Flush 2015 XC60
Old Apr 2, 2019 | 12:19 PM
brenbenj's Avatar
Default Coolant Flush 2015 XC60
Hello is a coolant flush part of normal routine maintenance? Owners manual states specifically "Normally the coolant does not need to be changed." But both my Volvo dealer and independent repair shop are recommending a coolant flush. Do most people do this every 20-30K miles assuming driving under normal conditions? Thank you.
Old Apr 2, 2019 | 01:41 PM
ES6T's Avatar
There is no specified interval but coolant does wear out over time or become dirty. Generally speaking, a flush every 3 or 4 years is a good idea.
https://esd.volvocars.com/local/us/2...-Manual-v1.pdf
Volvo recommends an anti-corrosion agent / test of the antifreeze rating every 20K miles - you'd get the same with a drain fill with new factory spec coolant. If you decide to do a flush don't use anything stronger than distilled water.
I'd venture to say, only a small percentage of people bother to flush their radiators every 20K.
urdrwho
Mar 2, 2014 09:29 AM
rspi
Oct 11, 2013 02:52 PM
jmaslanka
Feb 11, 2009 03:17 PM
sporky
May 24, 2008 09:40 PM
Psaboic
Dec 1, 2006 04:53 PM
