cruise control
Old Nov 22, 2007 | 07:44 PM
honeyfixthecar's Avatar
Default cruise control
new to this site, first volvo owned. a 1995 940 non turbo.
cruise control is not working ,have checked the fuse all vac lines connected and in good shape. have worked on american cars as machanic and restored many classics from frame up. having hard time finding any diagrams or info on this system can anybody head me in the right direction or tell me what else i need to check. other than a couple of genral minor fixes .brakes and that kinda thing this is the only factory item not working and my wife and i love the car it was given to use after she was in an accident with are only car at the time if they made pick ups i would get one too. thank you for any help you can give me.
Old Nov 23, 2007 | 06:03 AM
JPN's Avatar
JPN
Default RE: cruise control
Hello Sir,
I'm sorry about the CRZ CTRL.
Please note, that I'm an 850 driver and am not privy to the 940 lineup. Until 940 drivers show up, all I can suggest is that there may be a problem within the electrical system, likely the relay or the switch. 850s use relay for crz ctrl but am not sure if the setup for 940 is similar.
Anyway, please wait till people with better knowledge reply with accurate solutions.
JPN
Old Nov 23, 2007 | 11:57 AM
tripleb's Avatar
You can check the brake pedal switch. It has an electrical part, and a vacuum part.
I believe it vents vacuum when the switch is depressed, and also disconnects a power supply to the cruise control unit when the switch is depressed.
The switch may be out of adjustment.
Good Luck
B
[align=left] [/align]
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
Talon
Jun 1, 2005 01:04 AM
CFGVolvo850
May 24, 2005 12:38 AM
