Fan motor
Old Jun 30, 2011 | 03:40 AM
odie's Avatar
Cool Fan motor
Hello odie here,
just got a S60 2.0 se lux fan motor was replaced because it was loud and running fast got the new one its doing the same should I take back or is this normal.
Old Jul 26, 2011 | 03:02 AM
jollymark's Avatar
A ceiling fan is a device suspended from the ceiling of a room, which employs hub-mounted rotating paddles to circulate air.The electrically-powered ceiling fan was invented in 1882 by Philip Diehl (pronounced the same as "deal"). Diehl had engineered the electric motor used in the first Singer sewing machines, and in 1882 adapted that motor for use in a ceiling-mounted fan. "The Diehl Electric Fan", as it was known, operated like a common modern-day ceiling fan; each fan had its own self-contained motor unit, eliminating the need for costly and bulky belt systems.A fan is a machine used to create flow within a fluid, typically a gas such as air.
A fan consists of a rotating arrangement of vanes or blades which act on the air. Usually, it is contained within some form of housing or case. This may direct the airflow or increase safety by preventing objects from contacting the fan blades. Most fans are powered by electric motors, but other sources of power may be used, including hydraulic motors and internal combustion engines and solar power.
Fans produce air flows with high volume and low pressure, as opposed to compressors which produce high pressures at a comparatively low volume. A fan blade will often rotate when exposed to an air stream, and devices that take advantage of this, such as anemometers and wind turbines, often have designs similar to that of a fan.
ingydrummer
Feb 28, 2020 03:33 PM
norasaint
Sep 20, 2012 12:53 AM
elouadj
Jun 25, 2008 07:00 PM
Psaboic
Oct 29, 2006 07:12 PM
parrym
Nov 7, 2004 11:30 AM
