have fuel and fire wont start
Old Jun 23, 2010 | 02:05 AM
TMG's Avatar
TMG
Default have fuel and fire wont start
my 90,91 stwgn 740 wont start before it died totally it would run ok then it would run rough when you came to a stop, sometimes. sometimes i would not even be able to start it but eventually it would start. not any more. new wire plugs ck fuses, ck gas pressure, changed dist, fuel pumps seem to be ok. does anybody have an idea?
Old Jun 23, 2010 | 04:52 AM
Typhoon's Avatar
You need fuel, air, ignition and compression to make the car run and you need spark and valve timing at the right time.
So, check compression, spark timing with a timing light and valve timing for TDC.
Now, seeing as you have a 91, I would suspect the crank angle sensor.
Regards, Andrew.
Violetsjewels
May 25, 2015 09:48 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
waltonsauto
Jan 31, 2012 12:40 PM
joker834
Nov 15, 2006 10:15 PM
